unity script help
Go to solution Solved by trag1c,
https://docs.unity3d.com/ScriptReference/SceneManagement.SceneManager.LoadScene.html
SceneManager.LoadScene("Scene Name", LoadSceneMode.Single);
// Alternatively you can use the index specified in the build parameters of the project
int sceneIndex = 1;
SceneManager.LoadScene(sceneIndex, LoadSceneMode.Single);
I highly suggest looking at the documentation Unity has available because it has numerous examples available and it is easily searchable.
int sceneIndex = 1;
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
https://linustechtips.com/topic/1360672-unity-script-help/#findComment-14900922
