Favor: can someone with green coolant set all their RGB to red, and post a picture for me?
Go to solution Solved by airborne spoon,
Ok so I totally forgot and then randomly looked at my rig and remembered.
So here ya go.
This is green fluid, random brand it's UV reactive.
All pics have the UV on in the background.
Pictures never come out true to form, I normally run solid blue with the green fluid and it looks killer, so does it with RGB off.
White looks cool but the red is just blah, if I were to tone down the brightness of the RGB the red still overpowers the green.
The last one with UV only is a PITA to get an accurate pic, the UV really saturates the camera and I'm not too knowledgeable on all the fancy settings to get it right, but it's relatively accurate.
P_20210729_205039.thumb.jpg.dcb3317fae8edb706af63b865fec0ff2.jpgP_20210729_205128.thumb.jpg.2f044e09e4c35c12094dba7363f7486e.jpgP_20210729_202838.thumb.jpg.7a3390c56aaab5dba494fbae82368967.jpgP_20210729_205154.thumb.jpg.8d64748e583ff75b7eb0494059a5d420.jpgP_20210729_205602.thumb.jpg.7821713a67c78f85db289207c5d59707.jpg
I want to see what green coolant (like car coolant) looks like when the waterblocks and fans are all set to a red color theme, to see if I like it or not.
About to buy coolant for my loop, and I'm playing with ideas.
Thanks in advance!
Intel i7 8700k | Asus ROG Strix Z370-I | NVidia RTX 2070 Super Reference | Corsair Vengeance Pro RGB 3600MHz x 32GB | Samsung 970 Evo 500GB NVMe | Samsung QVO 1TB SSD | Custom Loop | Corsair RMx 850w Gold | Phanteks Evolv iTX TG (modded) | Acer Predator XB1
Thanks in advance!
Just buy the coolant and see if you like it or not
If you dont like it switcn coolant
u can also use coolant dye from EK to make green coolant 🙂
personally i prefer to use clear coolant for at least 6 months after loop setup, so i can monitor if there's any build up in my blocks
Ryzen 5700x + EK Supremacy D-RGB | 2x8 GB DDR4 Klevv 3200 MT/s | MSI B550M Mortar | Palit 3070 GamingPro LHR + Bykski N-PT3070PRO-X | Corsair RM750 | Alphacool EPDM + QDC | Aquacomputer Quadro + HighFlow2 | EK D5 XTOP | Freezemod 360 30mm rad + Barrow Dabel-20b 360 20mm | Barrow & Freezemod fittings | Corsair 5000D Airflow
Audio: beyerdynamic DT 900 Pro X + iFi ZEN Air DAC + Razer Seiren Mini
red lights on green fluid looks like shit. I have green in my loop and i have all the RGB set to blue and it looks pretty good. I'll try to remember when i get home today to take a pic with a few different RGB colors on the green fluid.
So here ya go.
@airborne spoonThank you, sir. I appreciate it.
