Ryzen 5 3600 Temperature Spiking
46 minutes ago, Ballisticc said:ok so i undervolted it and im getting pretty much the same results, but at higher degrees this time? the lowest its hitting is 51 Celsius
Thats the thing, they recently changed this in afterburner, looks way worse than it actually is, and these spikes are indeed completely normal
1 hour ago, Ballisticc said:Does your PC ever freeze up?
Does yours?
1 hour ago, Ballisticc said:ok yeah took me a bit longer than 15 minutes but the thermal paste is still pastey and hasn't dried up at all so i dont think thats the issue.
Did you replace the thermal paste after doing this? Thats absolutely necessary, because of possible air bubbles, etc.
Thats probably why you see higher temps now.
here, its absolutely normal,it jumps between 35 and 48C *all the time* and thats with a push pull noctua cooler - max temp during C23 is 71C btw…
It only stops doing that when its under load (running C23 here)
Just replace your thermal paste if you didnt already.
