Hello
So i was using AIDA64 Extreme earlier and i noticed that my CPU Core voltage varies VERY MUCH.
It's from like 1.0V to 0.870V to 0.500V to even 0.250V. Keeps going backwards and upwards but with this type of variety, this is on idle.
Is this normal, i mean so much variation ??
I'm using an Ryzen 5 3600, would greatly appreciate some info on this.
https://linustechtips.com/topic/1359247-cpu-core-very-low-voltage/
Not sure where you're getting the numbers, but software reporting is often inaccurate. However, unless you feel like the performance is compromised, it's nothing to worry about in any case. Running low voltage with the same performance is the dream. The problem is normally not being able to safely push enough voltage into it to scale the performance higher.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
@Chris Pratt
But isn't 0.400 or 0.330V considered too low ?
It's not often but it fluctuates... it kinda rarely goes so low but it does go sometimes.
Using AIDA64 Extreme.
46 minutes ago, Mikey89 said:
@Chris Pratt
Again, it can't technically be too low. The question is: is it impacting your performance? If not, then don't worry about it.
It's not affecting my performance but what is considered too low ?
Is 0.330 or 0.430V considered too low ?
Dude. For the 10th time, there is no such thing as "too low". The goal of the entire PC component industry is to get the most performance out of the lowest voltage. Voltage is something you increase because you *have* to.
Don't worry about the voltages. It literally does not matter at all. The only thing that matters is your performance. Period. If you were getting bad performance, voltage might be something to look at as a cause, but if your performance is fine, you're fine.
One problem i really have with AMD is their documentation about Ryzen CPUs… if you look up "specs" you arent getting anything on the AMD site (very little) except marketing  bs.
Theyre definitely not the only one doing this but one of the worst offenders for sure.
However:
Its not like they dont know, they just dont communicate it well, and thus sometimes appear as they dont know, and its just bad business practice to hide such information in random reddit threads of all things (which they do repeatedly)
I mean they explain it well *here* but whats the point when most of their customers will never read this…
-Scott Manley, 2021
However:
@Mark Kaine
HOLY CRAP that's spot on.
I was watching earlier with AIDA64 and i even got as low as 0.210V but it varies and then goes up to 1.0V. It doesn't stay fixed but it always varries from 1.0 to 0.9 to 0.4 to 0.8 to 0.3 etc
But is this normal though ??
2 minutes ago, Mikey89 said:
@Mark Kaine
It's normal.
Called P-states in short for Power States generally during idle and light usage, v-core can go as low as .20v while some threads will be parked/gated.
Every reading you see visually happened around 1000ms ago as well. They are not real time readings.
12 minutes ago, ShrimpBrime said:
It's normal.
Thanks for clearing it up... was hoping it wouldn't drop extremely low and make my PC hang.
I read on the web that if voltage is too low it might cause PC to hang or freeze.
it can, but if your pc doesnt crash there is no problem.
-Scott Manley, 2021
This is the first time I've ever seen someone post about low CPU voltage, let alone not having any issues.
I think software reporting voltage on Ryzen is bugged. Every Ryzen CPU I've used has shown voltage bouncing around like crazy
14700k
Thermalright frozen prism 360mm aio
B760 Aorus elite ax ddr5
32gb ddr5 G skill s5 6000mhz CL30
2tb wd black gen 4 nvme
2tb Solidigm P41 plus
2tb seagate hdd
Pny 5070ti
Fractal Ion 2+ 860watt platinum
Thermaltake View 380
AW2725DF 1440p 360hz oled
Aoc Q27G3XMN mini led
Ps5 Pro
Series X
I think its pretty normal.. It seemed a little more erratic on Zen 2 vs 3.
Highs and lows..
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
Highs and lows..
The highest recorded is what always got me. 1.5v is crazy high, but it's never like that for long.
14700k
2tb seagate hdd
Pny 5070ti
Ps5 Pro
Series X
I was in Predator Hunting Grounds earlier and was getting 1.4v if i remember right.
I checked with AIDA64 just outta curiosity to see how much i was getting while gaming.
Yeah idk if it's a software bug or if it's actually hitting that high sure a very short amount of time.
Every Ryzen system I've built has done that voltage crap. Ryzen 3600, 3700x, 3900x, I just quit looking at it since nothing ever went wrong
14700k
2tb seagate hdd
Pny 5070ti
Ps5 Pro
Series X
Oh yeah its hitting that high, I have seen 1.53 all on its own lol.. she's thirsty 🙂
Edit:
I am pretty sure I saw 1.55 from my old 3600XT..
Edit:
Why would AMD allow for such high voltage fluctuation though ?
To drive the top clocks, there is almost no amperage behind it. If you set 1.5v in bios it would be a very different story.
