i am making a lite coin based crypto that is almost ready but i have no clue what to do to cross compile if you can help the github link is https://github.com/TheFBIMaster/picocoin
i have been working in ubuntu 18.4 LTS on a VM until now my VM dump is on this link https://drive.google.com/file/d/1pksoFSF0VlVl9AXFz8TmTIcPi7JnpB-I/view?usp=sharing i am using virtual box this is the .vdi file
the dependences if you don't want to download the VM are
sudo apt-get install build-essential gcc make perl dkms
sudo apt-get install git
sudo apt-get install build-essential libtool autotools-dev automake pkg-config libssl-dev libevent-dev bsdmainutils
sudo apt-get install libboost-system-dev libboost-filesystem-dev libboost-chrono-dev libboost-program-options-dev libboost-test-dev libboost-thread-dev
sudo apt-get install libboost-all-dev
sudo apt-get install software-properties-common
sudo add-apt-repository ppa:bitcoin/bitcoin
sudo apt-get update
sudo apt upgrade
sudo apt-get install libdb4.8-dev libdb4.8++-dev
sudo apt-get install libminiupnpc-dev
sudo apt-get install libzmq3-dev
sudo apt-get install libqt5gui5 libqt5core5a libqt5dbus5 qttools5-dev qttools5-dev-tools libprotobuf-dev protobuf-compiler
sudo apt-get install libqt4-dev libprotobuf-dev protobuf-compiler
sudo apt-get install openssl1.0
sudo apt-get install libssl1.0-dev
then CD to desktop and clone the git repo
------------------------------------IMPORTANT--------------------------------------------
THIS NEED TO BE DONE ON UBUNTU 18.04 LTS OR IT WONT WORK
https://releases.ubuntu.com/18.04/ubuntu-18.04.5-desktop-amd64.iso.torrent
when you get a windows exe just add a pull request to the git repo and i will update the repo with a release
https://linustechtips.com/topic/1356537-i-need-help-cross-compiling/
