Triple Monitor Help
Jf8man
I am trying to find a 1440p 144hz thin or bezel-less monitor for around $200-$250. No curved please. I would like a power button in the middle of the display. I am going to use a triple desk mount that would make the monitors look like one monitor.
Thank you.
The AOC 24G2 seems to fit your usecase and is the best monitor in your price class.
Power button is on the bottom right, bezel-less at the sides and the top, plus overall a very good 24" IPS monitor.
If you're gonna spend $250 top then i'd stay away from 1440p 144Hz, because you'll only get mediocre budget options. Going for 24" 1080p makes more sense here imo.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
  • 2 weeks later...
I have 3 24 inch 1080p monitors already. Forgot to mention 27 inch is what I am looking for.
