Choosing a color accurate monitor
th3infinity
Hello everyone!
I am new to this forum so please excuse any posting mistake if this is not the right place for my topic !
I am looking for a new video editing and occasional gaming monitor. I do part time video editing, so the color accuracy is really important. I am totally aware that in order to achieve a state of the art accuracy I would need the screen to be calibrated, so I am open to any options about a calibration device as well.
After doing some digging I came across the following options:
Benq PD2700U -- https://www.benq.com/en-us/monitor/designer/pd2700u.html
Benq PD3200U -- https://www.benq.com/en-us/monitor/designer/pd3200u.html
Dell U2720Q     -- https://www.dell.com/en-us/shop/dell-ultrasharp-27-4k-usb-c-monitor-u2720q/apd/210-bbzu/monitors-monitor-accessories
LG 27UL850-W -- https://www.lg.com/us/monitors/lg-27UL850-W-4k-uhd-led-monitor#
Which one do you guys think might be "the best" ?
Do you know of any other option in this price range ? (under 800$)
Thanks!
out of those 4, the only one i'd use for any color work is the dell, just based on specs, this is better and the best 4k color monitor you'll get for the price
https://www.bhphotovideo.com/c/product/1594380-REG/msi_32_creator_ps321urv_monitor.html?gclid=CjwKCAjwieuGBhAsEiwA1Ly_naSEvdm-bJxhyWzIkxW7w8YrFhwnH_OhVGYg50C-qcit-lXWO4AUGxoC8FoQAvD_BwE
though for the amount you are already paying
Though i'd probably pay 1100 for this than anything under 800usd new
https://www.bhphotovideo.com/c/product/1545191-REG/asus_pa329c_32_wide_16_9_proart_4k.html (i paid 800 for something slightly worse and not 4k)
if u have to keep it under 800, then the msi is better than the 4 u listed, though the color coverage isn't better than some of the 1440p high refresh monitors, the cost comes from a combination of 4k and having decent colors.
if you don't need it to be 4k, then i found this one ebay used (i found one for 120usd shipped pre-covid)
https://www.ebay.com/itm/265204870865?hash=item3dbf712ed1:g:308AAOSwSctg0lyU#viTabs_0
which looks better than everything listed above except the asus
Personally i'd be picking between the NEC used or the asus new.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
Any monitor can be 'accurate' within its reproducible colour gamut, it just needs calibrating.
The vast majority of monitors come out of the factory with a poor calibration not suitable for colour accurate work, as such those who use displays in such ways need to invest in a basic colorimeter like an X-Rite i1 Display Pro.
The question is, What color spaces will you be working in, and what degree of cover do you want for those spaces for ur given task, 75%, 80%, 100% ?
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
