when i shut off the computer with the switch on the psu then turn it back on quickly it wont boot at all or anything so i hit the switch again on the psu till its off for 5-6 seconds then i switch the switch on and it boots its been happing across 5 different motherboards and the pc still runs fine its not making any weird sounds or anything so im wondering if its safe to use it with my pc
https://linustechtips.com/topic/1350837-psu-problem-help-please/
Why on earth are you doing this? Stop flipping the switch on the PSU off and on all the time and your problem is solved.
4 minutes ago, DarthBudgie said:
well ive been doing it for years im just curious why it like almost locks
I hope hdds are safe from you
If you don't quote us, we won't know you answered
I don't mean this in any negative way I'm only trying to understand why you are doing it, but do you have some form of behavioural tick or OCD where you need to flip switches off and on multiple times? If so all I can really suggest is moving the PC to a place where the switch isn't visible or easily accessible to hopefully remove the temptation to flip it. There are also some PSUs that don't have the switch, so if it is a big problem you could look at swapping it for a PSU without the switch on the back.
If that isn't the reason why you're flipping it off and on, just stop turning it off. PSUs are meant to be left on. You only need to turn it off if you're unplugging it or changing components which shouldn't be very frequently, and in those situations you won't need to quickly turn it back on as soon as you turn it off either.
ya i actually do have ocd but its not that i flip it  all the time i use it as  reset switch cause that doesnt work
25 minutes ago, DarthBudgie said:
i have the same hard drives for years too and they arent dead yet i have 350000 hours on one
Well that's interesting, how many hdds do you have ?
An hdd stopping rotating before the heads are parked could be devastating.
The heads crash with the fast rotating platters, damaging the surface (and the heads)
Only recently I discovered that hdds could use the rotating energy to still park the heads after power out.
Edit : But this is a safety feature, I wouldn't count on it.
no and its okay i didnt take offense but ok
i have  3 hard drives and 3 ssds
See if you can repair the case reset switch. Resetting from a reset switch on the case sends the signal to the motherboard to reset the system, it doesn't just abruptly kill power to the PSU like flipping the switch on the PSU does.
1 minute ago, DarthBudgie said:
cause windows turns it half off and then its not actually off like i like to cold boot windows everytime idk why
Windows is quite happy being put in standby/sleep/hibernation. You don't need to shut down and kill power to the system every time you use the PC.
how do i do that?
In the BIOS settings there should be an option for Quick Boot. Set it to disabled.
okay i was able to get the reset switch to work  and i disabled quick boot
so if i stoped doing it from here on out ill be fine right
I didn't get the Reset switch thing, why do you use/need the Reset switch ?
I don't even have a Reset switch on my case.
If I want to Reset, I select Restart from W10 or I push the "Power Button"on my case, then once more when it's shut off
