Need Advice... Legion Pro Vs Ryzen Alienware...
Solved by Darkseth,
Screw that Ram upgrade, it's not needed. You will never notice ANY difference, that will make these 150 bucks worth it.
Unless you want to upgrade 2x 8gb to 2x 16gb yourself, that's a different story.
I personally would get the Legion. it's cheaper, has very high Wattage for power (so it's not really slower), and has 16:10, which is so much better for anything that isn't gaming or Netflix/youtube.
Also, Dell doesn't give out much informations.
The Legion 5 Pro Display is one of the best Displays you can find in any Gaming Laptop right now, or maybe THE Best.
