GPU 3060 , overkill for dual 1080p 144hz and 60hz ?
Solved by SupaKomputa,
35 minutes ago, jaslion said:The 1600 does struggle to reach 144fps in newer games so if that is not happening and the gpu is not at 100% then op might want to consider upgrading.
The 3060 won't even do 144fps, best is around 80-110, which is still fine with 1600.
Featured Topics
Britishblue ·
Posted in Linux, macOS and Everything Not-Windows1 -
1
metronohm808 ·
Posted in New Builds and Planning4 -
INotPablo ·
Posted in Cases and Mods3 -
8
DahPython ·
Posted in CPUs, Motherboards, and Memory4 -
4
4
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
