How do I clean an LTT mousepad?
mcg_mm8
The title says it all. Is there any specific way, or can I clean it how I'd clean any other mousepad or deskpad?
It's like any other deskpad, clean it as you normally would.
First of all its an LTT pad, you dont make those dirty. 😄
Else i would suggest a mildly damp cloth and try and wipe it of, if more viscous try using paper to absorb it first.
I don't think you can use a washing machine for them, but you might have the dry cleaned if they really dirty.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
-= Topic moved to Peripherals =-
Reputation is a Lifetime to create but seconds to destroy.
 CHRISTIAN MEMBER
On 5/17/2021 at 7:13 AM, Biohazard777 said:
Sorry, had to do it. This thread screamed for a "WikiHow" reply.
this is the best post on this entire website. i feel blessed to have seen it.
Main PC: the literature club machine
Intel I5 9600k @ 4.2 Ghz | MSI z390-a pro | G.Skill Trident Z RGB 32 GB 3000Mhz | Samsung 970 Evo 500 GB | Seagate barracuda 3.5" 2.5tb  | Thermaltake Floe Riing RGB 240 | Asus GeForce GTX 1660 Ti 6 GB DUAL OC | Thermaltake Core P3 TG Snow Edition
Daily drivers
OPPO A52 | Razer Blackwidow Chroma | Razer Deathadder V2 Pro | Beryodynamic DT 990 PRO | Focusrite Scarlett solo gen 2
