System upgrade options - i9-9900x, 64GB DDR4, rtx2080ti to...?
1 minute ago, Woodenwealth said:OK thanks I'll try that. Sure it's a fair point - and I didn't get in to any of the issues I have so here goes:
Firstly, when working with some larger SketchUp models and Layout files I get some performance issues. As I understand it (and I'm prepared to be wrong) this is mostly down to the single-core CPU speed, and probably the RAM speed also? I think the i9-9900x socket limits the RAM to 2666mhz? So, I'm wondering whether swapping out theMB, CPU and ram might be worthwhile.
Secondly, and this is the difficult bit to reconcile, some of the rendering utilises multiple cores, so core-count well, counts. I guess there's no pleasing some hm?
I am quite prepared to wait another year or two if there simply isn't a significantly better option at present. I could also just use a VM when I need to I suppose...
Well single core performance is better on newer systems but it isn't a huge leap ( a 15% jump at best for your usecase isn't something I'd say that warrants a over 1k upgrade). Multi core rendering has indeed sped up but shouldn't you be able to use the gpu in all these applications normally? Especailly with nvidia's ray tracing optimized renderer it would just fly.
I would indeed just wait if you can,
