Does the Ryzen 9 5900x and RTX 3060 work ok together?
Solved by Moonzy,
7 minutes ago, Percival2644 said:Yeah I see where your coming from, so what combo should I go with do you think?
from high end to low end gaming rig:
CPU GPU
5800x 3090
3080
3070
5600x 3070
3060 ti
3060
that's how i would build my system, if it was for games
5600x + a 3080 would work fine too, for games, but i like having some extra cpu headroom
plus, it also depends on your gaming resolution, what games u play, and graphical settings
the list above is very very generic and isn't applicable for all type of scenarios
