Is it possible to hookup 2 2.1 speaker systems together?
fade2black001
Easiest way to do it is just to have cable splitter for the input whether be rca, standard 3.5mm or even 1/4" trs
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
Why not buy a 5.1 surround sound system for the price?
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
Because I already have the speaker systems
2 hours ago, ShearMe said:
do you want to utilize rear channels from surround sound content?
IDK
I bought a splitter and am very happy now. I get virtual SS anyways through windows and with these being THX tated as well I get movie theater sound quality. Its amazing
2 hours ago, fade2black001 said:
IDK
Virtual surround sound only works for headphones....
Aside from movies and games, almost nothing is mixed in surround. Also, THX rating doesn't really mean very much. It's mostly just marketing. There is really crappy equipment that is THX certified, and very good equipment that is not.
Well I am happy and they sound amazing. It sounds like I am getting SS through movies and shows through streaming services such as Netflix
It probably feels that way because you're simply getting sound from more speakers. You're still just splitting 2.1 stereo sound however, so by definition you're not hearing actual surround sound.
That said, you are the one that needs to listen to it and if it sounds good to you then that's all that matters.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
