Whats better, Dark Rock Pro 4 or NH-D15?
Solved by CommanderAlex,
1 hour ago, imide said:Damn ok, thats a bit sad. Is there a huge difference in temps? Also, would the 4000D work fine? That is my second choice. Or, can I just replace the fan with a 120mm?
The Corsair 4000D Airflow can fit CPU coolers up to 170mm in height, so both should fit just fine. Yes, like I said before, you can swap out the 2nd fan for a 120mm and keep the other 140mm in between the towers.
