Molex to 4 pin
TiCaHe
Hello, I was looking at buying an R9 fury to have while i wait for my new gpu. My plan was to later give it to my sister as an upgrade to her current pc.
I have two questions regarding this.
Her current set up a i5 2500 and a gtx 660, the psu is a antec 650W unit. Will the psu handle the upgrade or will it crash and burn? Some quick calculations puts the total at some where around 400 W (65+275+some other stuff)
My second question is.
The psu has a total of 4x4-pin connectors (2x8-pin). The card needs all of them, but the motherboard (a msi z77 bigbang) also need a 4 pin + the 24-pin and the 6-pin cpu. Could I a use all the 4-pins to the gpu and then buy a molex->4-pin adapter for the motherboard or is that a bad idea?
Thanks for any answers,
Tim
There is no 4-pin power connector that can be plugged into a GPU. You seem to be confusing the 4-pin or 8-pin EPS connector which is for the CPU, and the 6-pin or 8-pin PCIe connector which is for the GPU. These are not equivalent, and cannot be used interchangeably.
Generally speaking, if the PSU does not come with the connectors you need, then it is not suitable for your build.
BabyBlu (Primary):
  • CPU: Intel Core i9 9900K @ up to 5.3GHz, 5.0GHz all-core, delidded
  • Motherboard: Asus Maximus XI Hero
  • RAM: G.Skill Trident Z RGB 4x8GB DDR4-3200 @ 4000MHz 16-18-18-34
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2070MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 10 Pro
Roxanne (Wife Build):
  • CPU: Intel Core i7 4790K @ up to 5.0GHz, 4.8Ghz all-core, relidded w/ LM
  • Motherboard: Asus Z97A
  • RAM: G.Skill Sniper 4x8GB DDR3-2400 @ 10-12-12-24
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Corsair Vengeance C70, w/ Custom Side-Panel Window
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair AX760
  • Display: Samsung C27JG56 27" 2560x1440 144Hz Freesync
  • Cooling: Corsair H115i RGB
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
10 minutes ago, TiCaHe said:
6-pin cpu
I think you are confusing this with the gpu
There is no 4 pin gpu and no 6 pin cpu.
CPU connectors are 4 pin or 4+4/8 pin
GPU connectors are 6 pin or 6+2/8 pin
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
Thanks for the responses!
Sorry my bad, I mixed up the connectors.
The psu has 2x6 pin, 1x8 pin (how do you tell if it is a EPS or a PCIe connector? No markings) and 2x4 pin.
The cpu has a 8-pin, the motherboard has a 6 pin and the proposed gpu has 2x8 pin.
Is it possible to use the 2x4-pin for the cpu, the 8 pin combined with the 2x6-pins for the gpu and a molex to 6 pin for the MB?
It might not be optimal and look like shit but would it work? Or is it just to buy a new psu?
Cant tell if the 8-pin is EPS or if it is PCIe so don´t really know, also is it even possible to combine 2x4-pin to a 8-pin?
It is likely a 4+4 pin EPS connector. They do it this way for compatibility with motherboards that have just a 4-pin. For 8-pin motherboards, they are combined together.
It sounds like you are already using it to power the CPU which would make it an EPS connector, but it wouldn't make sense to have a solid 8-pin instead of a 4+4 pin. It's more common for a solid 8-pin to be a PCIe connector, although those are also usually done as 6+2 pin for compatibility reasons. If you aren't already using it to power the CPU, then it is most likely a PCIe connector. Providing the exact model name of the PSU would be helpful.
Everything except the last bit with the motherboard 6-pin. I could never advise adapting from a 4-pin molex to a 6-pin PCIe. Fortunately for you, that 6-pin connector on the motherboard is entirely optional. It's only "needed" for 3-way or more SLI. It's mostly a gimmick. The PCIe slot will get the 75W it needs from the 24-pin cable. So you can safely leave that motherboard 6-pin unconnected.
BabyBlu (Primary):
BigBox (HTPC):
  • Display: None
NAS:
  • Synology DS216J
Thanks, I was not aware of the optional 6-pin!
The psu is an "antec tpn 650xr" and the pc is currently using the solid 8-pin for the cpu with no issues. I find is stange to have the connectors fit in both a PCIe cards and the CPU, would it not lead to many people damaging their components?
It does not fit. It is keyed differently. I suppose if you use enough force, you'll make it fit, though. 🤔
Anyway, it sounds like you'll be needing a new power supply in order to use that GPU.
BabyBlu (Primary):
BigBox (HTPC):
  • Display: None
NAS:
  • Synology DS216J
Ok thanks for your help, but why would the psu come with both 2x4 and 1x8 pin if you only need one?
It's a server PSU. For it's intended use, it very well may have needed them all. Some modern consumer boards also are coming with an 8-pin and a 4-pin, or even two 8-pin connectors for the CPU, although usually plugging in the additional connector is optional. It's not an unusual configuration.
BabyBlu (Primary):
BigBox (HTPC):
  • Display: None
NAS:
  • Synology DS216J
