Is there a way of dismantling Cherry keys from the top?
SRRAE
I need to clean out some keys and put some lube on them.
Ive seen tools to open up keys to allow you to lube the springs but they all require to do this from the bottom.
Is there a way of opening up the keys from the top?
Not really. Technically it's possible but it is a massive pain in the ass. You're better off desoldering the board.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
Thats what I thought.  Its most of the keyboard, I dont fancy desoldering the whole keyboard..
Any easy way to lube the keys without dismantling
If the switch is clipped into a plate, you can't take it apart.
You said you only need to do this maintenance on some keys, you could desolder just those? You should only do that if you're entirely convinced you need to do that though, since desolder can be kind of tough.
I've done desoldering before, I'd dread having to desolder all those and solding back. sigh.
