850 W PSU for 5950X and 6900XT Ultimate Red Devil
Drins
Hello!   First post here.  So I recently built a system at the Microcenter in my area.  My system contains the 5950X and the Powercolor 6900XT Ultimate Red Devil.   I am concerned that the 850W Seasonic Titanium is not enough juice for the system as a while under stressed situations.  What are your thoughts on this matter?
Usually it would be dissuaded to use a 850 watt. However since its titianium rated and high wattage power supplies are in scarce supply it will probably work and you will have problems finding any better options
Given that it is a Titanium unit, 750Watt+ should be fine.
Full time technology enthusiast, part time IT.
So I shouldn’t be worried about potential long-term to the GPU and/or other parts?   From what I’ve been reading (yes, lol internet), low wattage can cause display issues, system shutdowns, etc.
Effiency is not quality. There are some titanium Psus that cannot handle 6900XT in anyway.
Not really.
system shutdowns
These can happen.
Some Seasonic Psus have problem wiht high transient spike and high power gpus liek your 6900XT. I do not know which ones tho.
What exact titanium Seasonic? If it has no problem with 6900XT it will be fine
I summon @jonnyGURU
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
If it works without shutdowns then there's nothing to be concerned about.
Tag or quote me so i see your reply
If there is a lot of noise in the sense 12V wire, the PSU will shut down. How do you know? Like the post above said if it shut downs then there is a problem.
That doesn't make sense.  If it's a Gold 750W, it can put out 750W.  If it's a Titanium 750W, it can put out 750W.  All efficiency means is it generates less heat from conversion losses.
You pop the sense wire out of the PSU side of 24-pin cable and see if it doesn't shut down.
