So im currently running 6 corsair fans which has maxed my comander out (the one that comes with the h150i elite) and im wondering if theres something i can use to run the rgb on a 7th fan?
I don't know how to help you on this, but why do you need a 7th fan? Idk your config of your fans, but It's not necessary for a 7th fan.
Current Setup: PC
Its mostly for the look, 3x 140's at front 3x 120's on top with the AIO and one 140 at the back
So pretty much like what linus did with the all white build?
Current Setup: PC
Yeah sorta like that! 🙂
Just now, hArDsTyLe2259 said:
Eyyyy thanks so much! Ill get one of those right away ❤️
np
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
