HELP I DROPPED A PIECE OF PLASTIC IN MY LOOP
Solved by For Science!,
11 minutes ago, Scoobah said:As the title states, I dropped the plastic tip to my squeeze bottle while filling my custom loop up and now it’s stuck inside, what do I even do??? The pump/reservoir in question is the Corsair XD3 rgb, I have 2 280mm rads, soft tubing, Corsair cpu block, ekwb, I’m still doing my leak tests but I have no idea how to get that plastic piece out but so far it’s not stopping the water from flowing. PLZ HELP
You'll have to drain, dissasemble and get it out. Otherwise leave it, its so big that it probably won't move from where it is, its not going to impact performance
