Samsung SSD 980 at half speed
Solved by wkjdfx,
Alright I think I just fixed the problem. The BIOS was automatically using x2 mode for the 980 slot for some reason, even though I am not using any SATA port that is sharing its bandwidth. Manually setting the slot to be x4 mode in the BIOS fixed the problem.
xmegaMind1 ·
Posted in Troubleshooting0 -
AngelaHornung ·
Posted in Windows0 -
Arvo.k ·
Posted in General Discussion4 -
Eowen ·
MmmmTaterss ·
Posted in Troubleshooting1 -
SuperCookie78 ·
Posted in Graphics Cards2 -
4
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
