Dell g5 5000 aio cooling
Solved by Analog,
5 minutes ago, CashelyCool said:ok thanks. speaking of which do you know of any that would be good?
There are many that are good, but you will need to measure the distance from the socket to the side panel. The G5 case is not as wide as normal cases so you will be constrained to whatever fits inside. That is if you want to be able to close the side panel. If you don't care you go as big as it gets with the cooler. Generally speaking you can fit in a cooler as big as the rear exhaust fan. Yours is 92mm, so you can fit a cooler that has a fan not bigger than 92mm as well. The Noctua NH-U9S Chromax Black is quite a good one for the size. You can take a look at that one. The Noctua NH-D9L is a small dual tower heatsink. Also quite a good one.
