help I need help choosing a TV.
Solved by Adrian_neuen,
There isn't a lot of difference between these TV's. It will probably come down to your loungeroom setup. If your really close to the TV then the curve may be useful, if your a little further away then flat is probably better. As for features? If you want HDR10+ the the Samsung 8 series, if you have the need for an Android TV interface, then the Sony. But it doesn't look like that model has Dolby Vision and Sony hates HDR10+ and don't support it. If you have a dark room and really want better color accuracy then the IPS panel in the LG may be better, but it's smaller.
I don't think you can really guess wrong with this limited amount of TV's to choose from, they will all act very similarly.
