Do I need more case fans?
2 minutes ago, Buktu said:So I have done another hour of testing, getting the results in the image below. It seems like the airflow in my case is not exactly great since the numbers are arund 10 degrees lower without my side panel (plus less RPM on both the GPU fans and the CPU fan).
~Snipped photo~I dont have any issues with the case fans, they are all working so I dont think the fan headers are dead. The question is just if more fans at the top would help to keep my case cooler.
The temperatures don't look too bad to be honest and are not excessively hot. That's a huge difference in temperature of a delta 10oC change. This case is a hotbox/furnace and I would rather swap it out with something like a Phanteks P400A rather than try and buy more fans to place inside the case due to the reasons I stated in my earlier post.
