MH751 audio quality is soso
Solved by rice guru,
2 minutes ago, burntcrisp said:It's not worse than my $7 earphone. Like i said, it's a very comfortable headset and i like it. But as for the sound goes? It's pretty much the same with my earphone and that's $54 vs $7 value. I bought this headset because of great reviews. And because of that, i even started thinking that it might be a defective one. Or like i said, maybe it's because of the cheap mobo.
Could very well be mobo. But the thing I suggest in this case is time. Let yourself find the nuances in the headphones and differences. It's what I and many other like to call brain burn in. But I'm not sure what a cheap $5 DAC amp can do but worth a try.
