M.2 Sata SSD HELP! DONT UNDERSTAND!
Solved by minibois,
2 minutes ago, Guy Lawrence said:I have an Asrock B450m steel legend Mobo. I currently have an Nvme drive in the M.2_1 socket and I'm looking to add and M.2 drive into the M.2_2 drive socket. From what i read in the manual that socket supports an M.2 M key drive up to Sata 6 gb. Will this Drive be supported? It's a B&M key drive. [WD Blue M.2 SATA]
It will work, correct.
Just keep in mind SATA3_3 will be turned off when using this M.2 slot, leaving behind three other SATA ports.
