How do you know what power cable to buy?
48 minutes ago, Aaralli said:Yet another reason I rely on people like you to help me out... I understood very little of that
Closer to an ELI5 answer:
Power bricks are rated for how many Volts they output, and how many Amps they *can* produce, at max.
聽
So, a 12V Power brick always produces 12 Volts.
聽
But if that brick is rated for 5 Amps?聽 It will only produce 5 Amps if the device is asking for that much power.聽 If it's asking for 2 Amps, it only outputs 2 amps.
聽
Your device that is 'rated for 2A' is probably only using ~1 Amp most of the time, because 2A is the max it'll use.
聽
It's kinda like a Faucet in your sink.聽 It has a maximum flow rate, but most of the time you don't turn it up all the way.聽 Your device using the power is controlling how much juice it wants coming from the brick.
