PC Motherboard Overheating (120c while other components are chillin at 30c)
vRSeer
Hey guys, so my friend has a pre-built (yes yes I know, but he didn't know how to build one and I wasn't around to help him, and he was on the clock so he had to), he recently had his motherboard changed out, now with his new motherboard, that thing overheats to around 120c all the time while all the other components are normal. He has case fans, he should have thermal paste n stuff, so could someone give me some reasons it could be overheating like that? His other components aren't like 3090s or anything, just some low tier stuff like 1050s and older AMD CPUs, but I did look at the voltages, they were a bit high 1.3 volts for the CPU, could that be it?
Edited by vRSeer
You guys asked for some specs, so I put them with the screenshot with the temps :)
What are the system specs?
We can't help if we have NO info about the system in trouble...
CPU?
Motherboard make + model?
PSU make and model?
Graphics card make and model?
etc?
It could be a faulty temperature sensor on the motherboard...because 120*C would mean the computer is ON FIRE, or the motherboard is LITERALLY melting.
That for the VRM / power phases are too weak to sustain power for CPU, and its running too hot.
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz
  • Gigabyte Z390 Aorus Master
  • Sapphire NITRO+ RX 6800 XT S.E + EKwb Quantum Vector Full Cover Waterblock
  • 32GB G.Skill TridentZ DDR4-3000 CL14 @ DDR-3400 custom CL15 timings
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO +  500GB Samsung 980 + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Lian-Li O11 Dynamic EVO XL
  • Ekwb Custom loop + 2x EKwb Quantum Surface P360M Radiators
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
Don't know if this actually translates into computer hardware specifically, but overheating is a common cause of trying to draw to much power.
So, easy thing, even if its not the cause, is to make sure everything has every power plug connected.
Some devices like the motherboard may have multiple power connectors.
CPU?
PSU make and model?
etc?
My last motherboard had a sensor stuck on 120 degrees. Wether it just started or had been under heavy load. Everting was cool to the touch.
44 minutes ago, FakeKGB said:
It would help if you told us which prebuilt and the specs of the PC.
I just did in the edit
CPU?
PSU make and model?
etc?
Edited with specs and temps
CPU?
PSU make and model?
etc?
There ya go (edit in some temps with it)
CPU?
PSU make and model?
etc?
I don't think it's a faulty sensor, the PC keeps on restarting randomly whenever you so much as close a few tabs too fast, let alone try and launch something.
So why did he change motherboards and why can't he just put the original motherboard back in there,  seems like an easy fix?
Or the sensor is faulty...
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
No clue what happened, he couldn't diagnose it himself so he sent it over to some guy to repair it, said the motherboard was the issue, got it replaced. (I don't think the sensor is faulty, it keeps restarting randomly, I think it's from the real heat)
Seems like the 'repair guy' messed something up then. (definitely didn't test it properly)
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
Yeah I know he's kinda bad repair guy for sure, took him 2 weeks to find a problem. I think he might have put in a bad motherboard in, shady fellow my friend said.
hold up, if the sensor is the problem, and the PC is fine, could it be restarting just because the sensor "thinks" it should restart
