cleaning thermal paste...with perfume.
Solved by Entropy.,
3 minutes ago, kawaiineko said:i didn't spray the perfume directly on the cpu, i sprayed like one or two spritzes on the paper towel itself then wiped it with it, and then i made sure to completely dry it, all of this was only done on the protruding part of the cu (don't remember it's name rn)
It's probably called the IHS. It's the raised shiny metal part of the CPU right? If so then just maybe wait a few days for the water to completely dry or use a tiny amount of rubbing alcohol to get rid of the smell, and then wait a few days for it to completely dry off (even after drying it off with a paper towel or something). Then just pop it back into your system, paste it up, and reapply the cooler.
