Is it bad to switch the hot and neutral polarity in AC?
Solved by manikyath,
functionally it doesnt matter, but for the sake of safety it does.
essentially, when wiring a switch on mains, you always want to break the live wire. if a sloppy technician along the way swaps wires and your switch now breaks the neutral, whatever you just turned off still has mains voltage supplied to it.
so yes... you can switch it without affecting the functionality of devices, but no, you should NEVER EVER swap them around in a house installation.
