Aftermarket Cooler Clearances
Solved by Bombastinator,
There are standards of measurement for that stuff you may be ignoring. The teaseract is an older case. It’s pretty wide though. I would personally go with the manufacturer’s measurement before yours. They had to build an assembly line based on those numbers. The 6600k though is 4/8. Be sure you’re not just throwing good money after bad. My personal move would be to get a big cheap used cooler that fits and clock to that level. Not sure how much longer a 4/8 chip of any stripe will game.
