Just need quick help
By
Hold-Ma-Beer
in Audio
in Audio
Solved by AbydosOne,
49 minutes ago, Hold-Ma-Beer said:Its name is: Intex IT 2000W 2.1 (Not the SB version)
Probably closer to 32W based on the specs, which is basically nothing. As long as you're not running everything wide-open at once, you should be fine on 5-6A.
HunterSVK ·
Posted in Troubleshooting0 -
Ozzi ·
Posted in Networking3 -
2
MadManMarsBar ·
Posted in Build Logs1 -
IAmAndre ·
Posted in New Builds and Planning7 -
4
3
Playgb2 ·
Posted in Troubleshooting1 -
2
1
play_circle_filled
Latest From ShortCircuit:
