It says that module mutagen is not installed but it is installed, I double checked. My script isn't named mutagen.py I am not using the latest pip because it also gives an error but I think its not the issue anyways. Is there any chance you know why it might be happening?
https://linustechtips.com/topic/1310742-python-module-error/
3 minutes ago, gabrielcarvfer said:
What OS? Do you have more than one python installation? To check that, open a command prompt/terminal and type "where python" or "whereis python".
WINDOWS 10
There's actually 3.
C:\Users\[Username]\AppData\Local\Programs\Python\Python39\python.exe
C:\Users\[Username]\AppData\Local\Programs\Python\Python38-32\python.exe
C:\Users\[Username]\AppData\Local\Microsoft\WindowsApps\python.exe
https://linustechtips.com/topic/1310742-python-module-error/#findComment-14523546
Post. the. error. and. your. code.
The easiest trap to fall into when you have multiple versions of python installed is installing a module for one version and trying to run your script with another.
To make sure, pick one (e.g. 3.9) and use the handy py.exe shortcut:
py -3.9 -m pip install --user mutagen
py -3.9 your_script.py
sudo chmod -R 000 /*
https://linustechtips.com/topic/1310742-python-module-error/#findComment-14523659
