Is this your PC? Because it's much easier to identify the parts with some more pictures and task manager/the BIOS.
Some parts that are impossible to identify include the CPU and the drives (HDD/SSD), because those are not visible.
The motherboard is from AsRock, probably the B450M-F.
CPU: AMD, not sure which. Likely a Ryzen 5/3, judging by the cooler.
Graphics cards: unknown. Looks like a lower end card, like a GT 1030.
RAM: Vengeance RGB?
Case: I am not sure.
PSU, SSD, HDD: Anyone's guess really, as these parts are not visible.
https://linustechtips.com/topic/1309150-pc-part-help/#findComment-14510048
1 minute ago, minibois said:
RAM: Vengeance RGB?
Nah, i think its the XPG adata rgn, you can see a nit of rgb on the side of the ram
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1309150-pc-part-help/#findComment-14510053
  • Definitely an ASRock B450M PRO4 Micro ATX AM4 Motherboard
  • Ryzen 3 or 5
  • Cheap GPU (maybe a 710 or something)
  • Might be Teamgroup T-Force Delta RGB RAM? Nevermind, doesn't have the logo.
No clue for case or PSU, though,
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
https://linustechtips.com/topic/1309150-pc-part-help/#findComment-14510055
Are you able to connect this to a monitor?
Can you get in the operating system (windows)?
if yes to both of these, you can check what CPU, GPU, how much ram, what speed of ram, and what storage types/sizes you have through opening task manager and going into the performance tab (you will have to click on more details tab when it is first opened if you have not done so already).
Why do you need to know? Just curious or something more? (Thinking this might help us better help you find what you need to know).
https://linustechtips.com/topic/1309150-pc-part-help/#findComment-14510086
40 minutes ago, Jeffdablopalt said:
its not my computer. Its my friends and they asked me to help them identify the parts since their pc wont turn on
im also curious to know
They also have part numbers on them.  all your friend has to do is look.
Slayerking92
<Type something witty here>
<Link to some pcpartpicker fantasy build and claim as my own>
https://linustechtips.com/topic/1309150-pc-part-help/#findComment-14510186
Whoever 'cable managed' that box makes me want to cry a little.
The parts list you got so far here, is probably about as good as you're going to get from a fairly unhelpful picture.
The motherboard will have printing on the front saying what it is, generally.  Tell your friend to look for it.
A CPU doesn't make much difference, and without removing the HSF and cleaning off paste, you can't tell by looking.
the GPU may have a sticker identifying it?
https://linustechtips.com/topic/1309150-pc-part-help/#findComment-14510458
The motherboard is from AsRock, maybe b450m
CPU: it is from AMD and look like it is a Ryzen 5 or 3
GPU: not latest cards, maybe a GTX 10 series or below.
RAM: XPG adata rgn?
don’t know about others.
Quote me for a reply, React if I was helpful, informative, or funny
PC Build:
  • CPU
    Ryzen 9 5950x
  • Motherboard
    ROG Crosshair VIII Hero (Wi-Fi)
  • RAM
    Corsair Vengeance LED (4x8GB)
  • GPU
    EVGA RTX 3090 OC
  • Case
    Corsair icue 4000x
  • Storage
    Samsung 970 EVO Plus 2TB x2
  • PSU
    Corsair RM1000X 80+ Gold certified
  • Display(s)
    ROG Swift PG278QR 27” x2
  • Cooling
    NZXT Kraken Z73
https://linustechtips.com/topic/1309150-pc-part-help/#findComment-14510866
