HyperX Fury S Speed vs Corsair MM300
Solved by PCGuy_5960,
On 2/22/2021 at 7:58 AM, Brooksie359 said:I Personally go almost exclusively logitech for mouse pads and mice.
Logitech mousepads have a coating that wears off after some use which slows them down considerably. They are good, but not the most durable.
On 2/22/2021 at 7:13 AM, ShadowlightGM said:I'm looking to get a new speed mouse pad, and I saw the Hyperx Fury S Speed Edition and the Corsair MM300.
Not really sure about the Corsair one, but the Fury S Speed is very slow, if you want a speed pad, the regular black version of the Fury S is much faster and isn't coated so you can wash it to "revive" the glide (the speed version is coated, so it will slow down even more over time). I've also heard good things about the MPC450 from endgame gear if you like speed (And it's cordura so it should be very durable).
