240mm aio or Tower Cooler for Ryzen 7 5800x
In terms of reliability the Noctua NH-D15 is as good as it gets. The only points of failure are the fans. And i've personally never had a Noctua fail on me (or have seen other who claimed they have). In terms of performance there is not that much difference between the D15 and AiOs. When a fan fails on an air cooler, it's not that bad (the D15 can also easily cool your CPU when only 1 fan is running) but when your AiO pump fails, your CPU will instantly overheat and your PC will shut down. Also there is the pump noise. It's probably the most noticeable noise that can come from your PC.
Like the others already said, only go for an AiO when you don't have space for a big air cooler, really like the looks, or want to OC your CPU to the absolute maximum (D15 has enough headroom to do that aswell though).
As i've seen plenty people using a D15 inside a Meshify C, i'd say go for the big air cooler.
