PS4 Pro and Ps5 Mixed in with a 5700 XT (4k Display)
thedarkdad3
I am looking for a Display that can output 60 FPS on both HDMI 2.0 and Displayport 1.4 @ 4k | Freesync or Gsync is not needed here but if it is there so be it.
 THE PC "may or may not be attached to this screen| however I thought I would include the GPU
One is drive for Ps4 Pro
Two is drive for Ps5
Three "spare"
Back in the day I remember you could not find both. It was either one or the other . The HDMI would only cap out at 30 FPS and you HAD to use DisplayPort. This monitor is going to be used for strickly Ps4 Pro and PS5 gameplay. Fiancé will be using it so she doesn't need latest and greats. Our space is limited to 28 inch max.
Windows 10 Latest Build
RAID 0 Samsung SSD 970 2tb EVO's (4Tb Store)
RTX 3090
9900k DELIDDED with custom copper Rockitcool @ 5ghz
H150i RGB PRO XT
Corsair Dominator Platinum 64GB (4x16GB) DDR4 3200MHz C16 Desktop Memory 1.35v XMP Profile
Phanteks PH-P1200PS 80+ Platinum - Built-in Power Splitter 1200W Fully Modular
Z390 DESIGNARE (rev. 1.0)
Top Mon #2 ASUS ROG SWIFT PG348Q | NVIDIA G-Sync 100hz
Bottom Mon #1 Alienware Overclocked Refresh Rate #AW3418DW G-Sync 120hz
Server: 2019 DataCenter Edition, 42TB Store RAID 6 | WD Gold Enterprise Class 7200 RPM,SATA 6 Gb/s, 256 MB Cache
