HELP! Bluetooth Mechanichal Keyboard sttoped working
Greetings!
Yesterday I bought a Redragon Draconic K530 which is a Bluetooth Mechanical Keyboard and Bluetooth USB adapter.
Until yesterday it was working just fine, but had an issue: Whenever the keyboard or PC (Win 10) went idle or turned off, they didn't reconnect automatically (it's an issue that won't happen if I pair it with my S9+) and the only "solution" was to disconnect the device from Windows and repair them again manually.
But today the issue went even further. Now Windows won't even recognise the keyboard whenever I try to pair them. Bear in mind that my phone recognizes the keyboard and my PC recognizes other devices such as my phone, but the PC won't recognise the keyboard. Also, I've tried anything that Google in English and Spanish had to offer, but maybe you can help me with something I missed.
Can you please help me with both issues (keyboard recognition and keyboard auto connect)?
Please, I'm desperate right now 😔 I have Discord, Zoom, Teams or whatever you want
OS Windows 10
CPU AMD Ryzen 5 1600 (AM4)
MOBO MSI B350 GAMING PLUS
RAM Patriot Viper DDR4 8 GB 2400 MHz and Crucial Ballistix 8 GB 2400 MHz (x2)
GPU NVIDIA GeForce GTX 970 4 GB GDDR5
SDD Samsung SSD 960 EVO 250GB
HDD Western Digital WD20EZRZ 2TP and TOSHIBA DT01ACA050 500 GB 7200 RPM
PSU Thermaltake 80+Bronce 500W
Edited by Lizar
OS Windows 11
CPU AMD Ryzen 7 3700X (AM4)
MOBO ASUS ROG STRIX B450-F GAMING II
RAM Patriot V4s Viper Steel RGB DDR4 8 GB x4 (32 GB) 3200 MHz)
GPU NVIDIA GeForce GTX 1660 6 GB GDDR5
SDD Samsung 960 EVO 250 GB (MVME) // Adata Su650 480 GB (SATA)
HDD Western Digital WD20EZRZ 2 TB 5400 RPM // TOSHIBA DT01ACA050 500 GB 7200 RPM
PSU NZXT Hale 82 V2 550 W 80+ Bronze
I have the same issue with the keymove snowfox 61... It will connect fine to my pc with the wire but wont with the bluetooth. (It stopped working for me after I updated my keymove with an update that said it contained 'power management' updated) My keymove snowfox connects to my chromebook/phone fine aswell. Part of me thinks its just a windows thing.
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
I don't who has the problem, but is getting on my nerves. This is unacceptable
OS Windows 11
