24 pin power cable?
Solved by Mark Kaine,
1 minute ago, HairlessMonkeyBoy said:Whether or not you use 20 pins or 20+4 pins, you should fully connect all of the connectors on the other side of the cable into the PSU.
Ok, I figured, since as said you don't even have this option with semi modular, thanks.
(now I'm wondering what happens if you *dont* plug in that second cable and why they're even split to begin with tho...)
