coil whine Coil Whine coresponding to GPU Load.
Solved by glenalz81,
55 minutes ago, RedShadow said:The back panel is completely normal but it's a pain to use it since it's under the desk
Quality issues and interference are known features on front panel audio. Do whatever you need to do to use the rear ports.
Featured Topics
AcidVinyl ·
Posted in Graphics Cards2 -
Phantasmagoria ·
Posted in Cooling0 -
BotherRed ·
Posted in General Discussion1 -
GOATWD ·
Posted in Operating Systems8 -
Wubb ·
Posted in New Builds and Planning3 -
erico2304 ·
Posted in Troubleshooting1 -
aisle9 ·
Posted in Peripherals1
