Dolby Atmos/DTS:X with 4k 120Hz HDR
Solved by Stahlmann,
47 minutes ago, masonan96 said:Okay I was worried that the HMDI 2.1 was unable to deliver 4k 120hz HDR with 5.1.2 sound based on bandwidth limitations. If not, then yeah its an easy solution. I won't be using a sound bar but I can use the eARC port on a Audio Receiver.
Good to know about the TV having upscaling on board, I will run a 5e cable up to the TV then and just use it's built in upscaling and streaming services. Saves me a few hundred dollars.
Thanks!
Happy to help!
The bandwidth is nothing you have to worry about. 48Gbit 2.1 is enough for 4K 120Hz 12-bit HDR and eARC all at the same time. And even the 40Gbit the CX has is enough for 4K 120Hz 10-bit HDR with eARC.
