Oculus Rift Dk2 has Gsync/freesync like tech ?!?!!
EDIT
NVM i got my ass handed to me when i mention this on reddit .....
they had some good reasons i suggested was wrong
in their new video  1:10 - 1:23
i believe it has Variable VBlank
"our low persistence display shows and image only for a brief amount of time then display goes dark until the next frame comes "
no judder
it waits until the next frame !
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
https://linustechtips.com/topic/129288-oculus-rift-dk2-has-gsyncfreesync-like-tech/
Whichever person it was that had the idea to do this must've been sitting down somewhere staring at the wall then..
i really like the guys over at oculus if it was sony they will implement this feature as revolutionary and have it on CV2 lol ...
This idea is very similar to g-sync so is not their idea but I am happy that they did it. Better for us.
Gsync isnt even nvidia's idea
its been a Vesa standard well before Gsync ever started
*sigh* My wallet is gonna HATE me...
EDIT: I hope oculus isn't going to be bothersome to wear with glasses and a headphone on.... x.x
Like watching Anime? Consider joining the unofficial LTT Anime Club Heaven Society~ ^.^
I am really getting it.
I want one of these so bad, butter smooth gameplay with VR? Oh god.
NVM what i posted
they had some good reasons on what i suggested was wrong
since VSync is required for VR  every refresh is going to be a frame
they might be wrong .....
You have misunderstand what he said, he didn't talk about gsync like technology at all. Instead what he talked about was low persistence tech, which is what lightboost 2 monitors can do with the strobed backlight. The idea with the OR is not to use gsync but instead to ensure much higher FPS and use strobed backlight low persistence to reduce motion blur. That video didn't suggest gsync at all unfortunately.
wat. I covered this in my oculus crystal cove overview - its called low persistence
Its not Gsync or Freesync, its an OLED technology where it switches the panel on and off
what i thought he meant in the latest video is that "it waits for the next frame"
which sounds like variable VBlank tech
but ignore what i said  earlier because of new info
NVM what i posted
Well, most people who can lay enough money down for one of these is probably going to have a decent pc right?
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
its not quite the same as g-sync. It more of just a property of the kind of panel being used.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
This is not the same thing as G-Sync. G-Sync is when a game of piece of software randers a frame and the refresh rate of the monitor is synced to the framerate. An oscillating backlight is where the backlight turns off in between screen refreshes. So when he says the backlight waits until the next frame he means the next refresh and not next actual frame. This is a lot more similar to Lightboost which is an Nvidia technology intended for 3D but is commonly hacked to run at 120hz. I hope I could help people understand the diffrence.
"If you do not take your failures seriously you will continue to fail"
its only 350$
hardly say its expensive
this is an investment that will out last your PC
its like buying a monitor
The consumer version is targeting $200 or so, they aren't trying to make it expensive. The second dev kit obviously has changed quite a lot from the first one and we will see more progress towards the consumer version. There is still a content issue but its looking like at least a few games coming out this year will support it properly.
