x*x+y*(-y)
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1291212-xyx-y/#findComment-14372839
(a+b) * (c+d)
expands to
a*c + a*d + b*c + b*d
now put in the x and y (don't forget the minus sign in front of the second y) and you get
x*x + x*-y + y*x + y*-y
which is the same as
x*x - x*y + x*y - y*y
you can see the middle two terms cancel out and you're left with just x*x - y*y
https://linustechtips.com/topic/1291212-xyx-y/#findComment-14372874
Enderman answered it well.
But going a step further, in addition to what they've said
This his how I would explain it to someone who just doesn't understand the "expand" thing of :
(a+b) * (c+d) = a*c + a*d + b*c + b*d
(x+y) * (x-y) is the equation while (a+b) * (c+d) is the basis of it
You need to multiply each numbers of each parenthesis, with the numbers of the other parenthesis.
And do so in order.
Lets start with a*c
You take the x in the first parenthesis and you multiply it with the x in the other parenthesis.
x*x
This equals x². Why x² ? Because the exponent is just a number that tells you how many times you should multiply the number it is attached to, by itself. x² = x*x
Now you follow up with a*d, still with the x of the first parenthesis, but this time, with the y of the second parenthesis.
x*-y
This becomes -xy
Why is it a minus? Because a positive times and negative, always result in a negative. And y in the second parenthesis is negative.
So now you’ve found the multiplication values of the x, or a*c + a*d
x² – xy
Alright, now lets do the same with the y, starting with b*c
Take the y of the first parenthesis, it’s a positive because it has a + in front a it. Multiply it with the x of the second parenthesis.
+ xy
Now our answer should look like this thus far :
x² – xy + xy
(this is a*c + a*d + b*c)
Why did I write it xy instead of yx? Simply because it’s easier this way to not get confused, but it would’ve been valid regardless.
And now, all that's left is b*d. We multiply the y of the first parenthesis with the y of the second parenthesis. A plus multiplied with a minus equals a minus.
+y * -y = -y²
Almost done!
Our equation is complete, it now look like this
a*c + a*d + b*c + b*d = x² – xy + xy -y²
Simply do the addition between -xy and +xy. They cancel each other, so think of it as -1 + 1 = 0
The result is
x² + 0 - y²
Get rid of the 0 because it's meaningless and you get x² - y²
https://linustechtips.com/topic/1291212-xyx-y/#findComment-14376639
