Help me help my son on his graphics card upgrade.
He saved up and has finally built his PC. Below is what he put together. The only old part is the GPU that he put in my old Phenom II work PC.
We just need help selecting the best budget GPU. Any help would be appreciated!
This is his first PC build and he is very proud of it. He doesn't have a lot of money to spend on the GPU.
Budget (including currency): sub $300 US
Country: USA
Games, programs or workloads that it will be used for: various games, Fortnite, Rocket League, COD
Existing Setup:
MB -  GIGABYTE B550M DS3H
PSU - EVGA 600w
CPU - Ryzen 5 3600
GPU - GeForce GT 1030 Phoenix Overclocked Single-Fan 2GB GDDR5
HD - Crucial 2.5" SSD
RAM - G.Skill 16GB (2 x 8GB) Ripjaws V Series DDR4 PC4-25600
MONITOR - Acer KA272 1080p Freesync
https://linustechtips.com/topic/1289398-first-build-with-my-son/
Currently prices are way high so if you wait for sometime you can get a much better deal. But this is good for right now.
PCPartPicker Part List
Type Item Price
Video Card MSI GeForce GTX 1650 SUPER 4 GB AERO ITX OC Video Card $293.39 @ Amazon
  Prices include shipping, taxes, rebates, and discounts
  Total $293.39
  Generated by PCPartPicker 2021-01-04 00:00 EST-0500
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
I would buy used from ebay heres what i recommend
r9 290 ~ $100
gtx 1070 ~ $180
gtx 1070ti ~ $250
all are about the same bang for the buck just depends on how much power you need
OUTDATED JAN 2021 ===========> Check out my pc building guide! might be useful tho
It's great for planning new builds, getting a reference on where to start, or seeing what you need to play what games.
It also shows what I recommend for upgrading your stuff!
cpu - ryzen 5 3600
gpu - gtx 1070
ram - (2x8) 3200mhz
ssd - 970 evo plus 500gb
ssd2 - 860 qvo 1tb
mobo - asrock b450m hdv r4.0
psu - evga b5 550w bronze
i bought mine in november at that price. i even seen em as low as 175!
cpu - ryzen 5 3600
gpu - gtx 1070
ram - (2x8) 3200mhz
ssd2 - 860 qvo 1tb
Used may be the best option if you cannot not find anything new for the correct price, so...
35 minutes ago, richodude said:
r9 290 ~ $100
gtx 1070 ~ $180
Or a used GTX 970 ~ $100, or 980 ~ $150, or a GTX 1060 6GB ~ $150. Just be a little patient and you can snag something for a good price.
I really wish there was some new stuff available for the correct price but used may be the way to go for now.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
Thanks for the help!
He is up and running now with his old card so he can wait if that's the best option. What card / price point should we wait for?
Would it be better to take advantage of the free sync monitor he has with a Radeon or does it really matter?
It would be very good to use free sync.
Wait for the 5600xt for sub 300 or at 300$
Also quote people so they see replies.
Desktop :
Laptop :
If he isn't going to be playing super demanding games, the USD$200 mark for a half decent card is the way to go, he shouldn't need anything higher than a 970 or thereabouts for esports and fortnite type games. I'm running an RX480 8GB reference for battlefield 1 and Battlefront 2 at 1080 60fps ultra settings and it doesn't skip a beat.... I got mine for $130 which was a bit of a deal.  Usually they go for more in the $150 range.
Right now he's just playing Fortnite type games but I'm sure he will eventually mature to bigger and better games. But he can always upgrade when he gets to that point. He's only 13 so hell prolly want to up in in about 2 years.
On 1/4/2021 at 1:32 PM, BiotechBen said:
Unless he wants to go AAA titles at max settings, a 1060 6GB or rx 480/580 8GB should do him well for quite a while. I only say more than 4GB because I've seen mine spike to
5-6GB on occasion.
Is there a big difference between the 480 and the 580 for fortnite type games?
No. The 580 is basically the 480 with slightly higher clocks and power limit.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
Basically, any new GPU is non-existent. After researching, I found that the RX 580 8GB was an ideal card for bit mining so any used one would be a high risk.
I did find a few of the 4GB version (sold as new) being sold by a computer dealer that pulled them out of the HP Omens. It a single fan version and looks very OEM but at $200 I think it's worth a shot. Once I get it, I'll stress test it to make sure there aren't any issues. Hopefully I won't run into any driver issues with it being straight out of an HP.
I think it should be good enough for now and he can upgrade it again when prices go down.
There is nothing inherently risky about buying a card that's been used for mining. Miners who actually know what they're doing with multi-GPU mining rigs undervolt their cards and take care of them. The danger would be some dumb kid trying to mine on one card in their spare time with no research.
