Bluetooth 4.0 dongle not detecting my device
Solved by kirashi,
1 minute ago, iVictory Victor said:1. Thanks so much for being so helpful and considerate
2. Thanks for the advise, you're amazing, I think I'll return these tomorrow or when I get back to the store and try the one's you suggested to me
3. Yes, that's how my screen looks like, like in the picture when trying to pair.
Sounds like a plan. I don't mean to rain on your Bluetooth parade either by the way - I've just found that many off-brand dongles and/or no-name Bluetooth devices can be very fickle when it comes to working as advertised, so it's worth trying different models of products from different manufacturers to determine where the problem is.
