Is it possible to have two identical desktops and bring the hard drives between them
Solved by starry,
Just now, parker02311 said:Is it possible just to have separate C drives and the have D and F drives that I could take back and forth without the activation issue, and either way I was planning on them both being identical.
Yeah just make 2 different C drives, and take the external drives back and forth with you that have all your files. I like to tinker with my linux installation so I keep literally nothing on my install drive, its all external (incase i break it).
