Just now, Lilpete966 said:
anyone have the same issue? my computer is always quiet until i went onto fortnight and played at ultra settings, and through my headphones what i heard was what sounded like a jet engine roaring
That's because fortnite is a game, and is putting the PC under load so it has to spin the fans faster. What is the CPU and GPU temp? It's possible something is wrong though. What are the PC specs too.
Yours faithfully
https://linustechtips.com/topic/1284537-jet-engine-pc/#findComment-14325655
gpu temp is 69c
https://linustechtips.com/topic/1284537-jet-engine-pc/#findComment-14325664
12 hours ago, PeachGr said:
It can even be the power supply, those get loud. List your pc specs if you have them
my specs:
rx 570
i5 4590
12gb ddr3 ram
250gb ssd
500w EVGA br psu
https://linustechtips.com/topic/1284537-jet-engine-pc/#findComment-14327352
38 minutes ago, Lilpete966 said:
my specs:
rx 570
i5 4590
12gb ddr3 ram
250gb ssd
500w EVGA br psu
I think your whole system runs to the max. You can lower field of view, anti aliasing and shadows to have a better experience, but I guess fans will still be loud. If course you can change the CPU cooler if it is the Intel fan, but the sound does not indicate a problem
https://linustechtips.com/topic/1284537-jet-engine-pc/#findComment-14327414
33 minutes ago, HairyChickens said:
At what temperature do you think I should be like "hey I should probably open up my PC/Laptop and see if there is dust blocking the cooling"
If it sounds like a jet engine and hasn't been cleaned within the last six months and/or hasn't had its thermal paste replaced in the last couple of years, I'd open it up and do those things regardless of temperature.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/1284537-jet-engine-pc/#findComment-14328399
Anything over 85°C for a GPU or 95°C for a CPU assuming stock cooling, but really those are the temps that are very high and obviously something is up. If both parts have good coolers, anything over 70°C would make be double check cooler mounting, paste and dust.
Yours faithfully
https://linustechtips.com/topic/1284537-jet-engine-pc/#findComment-14328772
