Corsair RMx or Be quiet! Straight power 11
wolfff
1 minute ago, wolfff said:
title is da question
They are both great PSU's.
But your title of "Corsair RMx or Be quiet! Straight power 11" isn't a proper question, without the context needed to judge a PSU. You didn't mention your PC parts, case, etc.
So I'm sticking with my general "they are both great" answer.
both are gold certified, the be quiet is multi rail and the corsair isnt. idk the difference between that tho
What wattage? What are your PC's components?
Desktop:
CPU: Ryzen 5 5600x  | Cooler: be quiet! Dark Rock 4 | Motherboard: Gigabyte B550 Aorus Pro AC | RAM: 2x8GB Crucial Ballistix 3200MHz | GPU: Asus GTX 1070 ROG Strix | PSU: ADATA Core Reactor 850W | Case: be quiet! Pure Base 500DX | HDD: Samsung HD502HJ 500GB | SSD: XPG M2 SX8200 Pro 512GB | SSD 2: Crucial MX500 500GB | Microphone: Blue Snowball iCE | Headphones: Corsair HS70 Wireless | Soundcard: Maya U5 5.1 | Speakers: Genius SP-HF1800A | Phone: Samsung Galaxy S10
Secondary Desktop:
CPU: Intel i7 4770k @stock | Cooler: Cooler Master Hyper 212 Evo | Motherboard: Asus Z97-PRO (Wi-Fi AC) | RAM: 2x8GB 1600MHz DDR3 | GPU: Asus GTX 1070 ROG Strix | PSU: OCZ ModXStream Pro 700W | Case: SilentiumPC Aquaris X70W | HDD: Samsung HD502HJ 500GB | SSD : Corsair Force LS 240GB
ASUS ZenBook Pro UX550VD:
CPU: i5-7300HQ | RAM: 8GB DDR4, 2400MHz | GPU: GTX 1050 + Intel HD Graphics 630 | Storage: 512GB M.2 SSD
You can watch an explanation of single vs multi rail here:
Desktop:
Secondary Desktop:
i get what you mean sorry for that, but forget the parts in my pc. i only want to know wich one of those is the better psu. i mean both are great indeed but the one is prolly better than the other
dont mind the pc components or wattage, i just want to know wich one is better :)
Alright, so, here are the pros and cons of Straight Power 11:
And here are the pros and cos of RMx PSUs:
So, in conclusion, both are awesome and honestly, I'd go for the cheaper one.
Desktop:
Secondary Desktop:
guess i am going w corsair than bc they have 10 years warranty instead of 5. i will probably already have build a new pc by 5 years but still.. corsair has always done me right. expect when it came to ram warranty. they fucked me over haha.. oh well
Depends on what you're powering, which wattage models you are looking at, and their prices. Depending on where you're buying from, you might also be better off with neither.
