RPi.GPIO python module refuses to install in Visual Studio Code
I'm trying to install the raspberry pi GPIO module in Visual Studio Code but it just refuses to do so, originally it needed visual c++ which I got from microsoft's website and I don't really have any idea as to why it doesn't want to install. I tried launching Visual Studio Code with administrator privileges as well and still nothing. Also I have all these versions of Visual C++, most of them I don't think I installed myself anyway.
Collecting RPi.GPIO
  Using cached RPi.GPIO-0.7.0.tar.gz (30 kB)
Building wheels for collected packages: RPi.GPIO
  Building wheel for RPi.GPIO (setup.py) ... error
  ERROR: Command errored out with exit status 1:
   command: 'c:\users\andrei\appdata\local\programs\python\python38-32\python.exe' -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'C:\\Users\\Andrei\\AppData\\Local\\Temp\\pip-install-tkjr4jwu\\rpi-gpio_fc34c505547743b394f7e79bee903ae4\\setup.py'"'"'; __file__='"'"'C:\\Users\\Andrei\\AppData\\Local\\Temp\\pip-install-tkjr4jwu\\rpi-gpio_fc34c505547743b394f7e79bee903ae4\\setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d 'C:\Users\Andrei\AppData\Local\Temp\pip-wheel-7tggycbf'
       cwd: C:\Users\Andrei\AppData\Local\Temp\pip-install-tkjr4jwu\rpi-gpio_fc34c505547743b394f7e79bee903ae4\
  Complete output (18 lines):
  running bdist_wheel
  running build
  running build_py
  creating build
  creating build\lib.win32-3.8
  creating build\lib.win32-3.8\RPi
  copying RPi\__init__.py -> build\lib.win32-3.8\RPi
  creating build\lib.win32-3.8\RPi\GPIO
  copying RPi\GPIO\__init__.py -> build\lib.win32-3.8\RPi\GPIO
  running build_ext
  building 'RPi._GPIO' extension
  creating build\temp.win32-3.8
  creating build\temp.win32-3.8\Release
  creating build\temp.win32-3.8\Release\source
  C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Tools\MSVC\14.28.29333\bin\HostX86\x86\cl.exe /c /nologo /Ox /W3 /GL /DNDEBUG /MD -Ic:\users\andrei\appdata\local\programs\python\python38-32\include -Ic:\users\andrei\appdata\local\programs\python\python38-32\include "-IC:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Tools\MSVC\14.28.29333\include" /Tcsource/py_gpio.c /Fobuild\temp.win32-3.8\Release\source/py_gpio.obj
  py_gpio.c
  c:\users\andrei\appdata\local\programs\python\python38-32\include\pyconfig.h(59): fatal error C1083: Cannot open include file: 'io.h': No such file or directory
  error: command 'C:\\Program Files (x86)\\Microsoft Visual Studio\\2019\\BuildTools\\VC\\Tools\\MSVC\\14.28.29333\\bin\\HostX86\\x86\\cl.exe' failed with exit status 2
  ERROR: Failed building wheel for RPi.GPIO
  Running setup.py clean for RPi.GPIO
Failed to build RPi.GPIO
Installing collected packages: RPi.GPIO
    Running setup.py install for RPi.GPIO ... error
     command: 'c:\users\andrei\appdata\local\programs\python\python38-32\python.exe' -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'C:\\Users\\Andrei\\AppData\\Local\\Temp\\pip-install-tkjr4jwu\\rpi-gpio_fc34c505547743b394f7e79bee903ae4\\setup.py'"'"'; __file__='"'"'C:\\Users\\Andrei\\AppData\\Local\\Temp\\pip-install-tkjr4jwu\\rpi-gpio_fc34c505547743b394f7e79bee903ae4\\setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record 'C:\Users\Andrei\AppData\Local\Temp\pip-record-7zhmg0u0\install-record.txt' --single-version-externally-managed --compile --install-headers 'c:\users\andrei\appdata\local\programs\python\python38-32\Include\RPi.GPIO'
    running install
    running build
    running build_py
    creating build
    running build_ext
    py_gpio.c
ERROR: Command errored out with exit status 1: 'c:\users\andrei\appdata\local\programs\python\python38-32\python.exe' -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'C:\\Users\\Andrei\\AppData\\Local\\Temp\\pip-install-tkjr4jwu\\rpi-gpio_fc34c505547743b394f7e79bee903ae4\\setup.py'"'"'; __file__='"'"'C:\\Users\\Andrei\\AppData\\Local\\Temp\\pip-install-tkjr4jwu\\rpi-gpio_fc34c505547743b394f7e79bee903ae4\\setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record 'C:\Users\Andrei\AppData\Local\Temp\pip-record-7zhmg0u0\install-record.txt' --single-version-externally-managed --compile --install-headers 'c:\users\andrei\appdata\local\programs\python\python38-32\Include\RPi.GPIO' Check the logs for full command output.
sudo chmod -R 000 /*
14 minutes ago, Sauron said:
Still doesn't work for some reason. kind of already installed that but didn't have the W10 SDK, also the new installer doesn't have any 2017 stuff. Not sure if there's anything I missed. Also now it looks like trying to install the module it just spits out a bunch of syntax errors for some reason
Collecting RPi.GPIO
   command: 'c:\users\andrei\appdata\local\programs\python\python38-32\python.exe' -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'C:\\Users\\Andrei\\AppData\\Local\\Temp\\pip-install-goxasihn\\rpi-gpio_cc917e7721f74632b535128a0a9be8f6\\setup.py'"'"'; __file__='"'"'C:\\Users\\Andrei\\AppData\\Local\\Temp\\pip-install-goxasihn\\rpi-gpio_cc917e7721f74632b535128a0a9be8f6\\setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d 'C:\Users\Andrei\AppData\Local\Temp\pip-wheel-s26uyn_j'
       cwd: C:\Users\Andrei\AppData\Local\Temp\pip-install-goxasihn\rpi-gpio_cc917e7721f74632b535128a0a9be8f6\
  Complete output (24 lines):
  running bdist_wheel
  running build
  running build_py
  creating build
  running build_ext
  C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Tools\MSVC\14.28.29333\bin\HostX86\x86\cl.exe /c /nologo /Ox /W3 /GL /DNDEBUG /MD -Ic:\users\andrei\appdata\local\programs\python\python38-32\include -Ic:\users\andrei\appdata\local\programs\python\python38-32\include "-IC:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Tools\MSVC\14.28.29333\include" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.16299.0\ucrt" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.16299.0\shared" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.16299.0\um" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.16299.0\winrt" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.16299.0\cppwinrt" /Tcsource/py_gpio.c /Fobuild\temp.win32-3.8\Release\source/py_gpio.obj
  py_gpio.c
  source/py_gpio.c(87): error C2143: syntax error: missing ';' before '{'
  source/py_gpio.c(200): error C2143: syntax error: missing ';' before '{'
  source/py_gpio.c(227): warning C4047: 'return': 'PyObject *' differs in levels of indirection from 'int'
  source/py_gpio.c(345): error C2373: 'output': redefinition; different type modifiers
  C:\Users\Andrei\AppData\Local\Temp\pip-install-goxasihn\rpi-gpio_cc917e7721f74632b535128a0a9be8f6\source\constants.h(29): note: see declaration of 'output'
  source/py_gpio.c(345): error C2143: syntax error: missing ';' before '{'
  source/py_gpio.c(359): warning C4047: 'return': 'PyObject *' differs in levels of indirection from 'int'
sys.argv[0] = '"'"'C:\\Users\\Andrei\\AppData\\Local\\Temp\\pip-install-goxasihn\\rpi-gpio_cc917e7721f74632b535128a0a9be8f6\\setup.py'"'"'; __file__='"'"'C:\\Users\\Andrei\\AppData\\Local\\Temp\\pip-install-goxasihn\\rpi-gpio_cc917e7721f74632b535128a0a9be8f6\\setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record 'C:\Users\Andrei\AppData\Local\Temp\pip-record-3mgv8gyr\install-record.txt' --single-version-externally-managed --compile --install-headers 'c:\users\andrei\appdata\local\programs\python\python38-32\Include\RPi.GPIO'
    running install
    running build
    running build_py
    creating build
    running build_ext
    py_gpio.c
ERROR: Command errored out with exit status 1: 'c:\users\andrei\appdata\local\programs\python\python38-32\python.exe' -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'C:\\Users\\Andrei\\AppData\\Local\\Temp\\pip-install-goxasihn\\rpi-gpio_cc917e7721f74632b535128a0a9be8f6\\setup.py'"'"'; __file__='"'"'C:\\Users\\Andrei\\AppData\\Local\\Temp\\pip-install-goxasihn\\rpi-gpio_cc917e7721f74632b535128a0a9be8f6\\setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record 'C:\Users\Andrei\AppData\Local\Temp\pip-record-3mgv8gyr\install-record.txt' --single-version-externally-managed --compile --install-headers 'c:\users\andrei\appdata\local\programs\python\python38-32\Include\RPi.GPIO' Check the logs for full command output.
Why are you installing Visual Studio, Windows SDK and C++ - development tools, when you're trying to use a Python - module in Visual Studio Code? Visual Studio and Visual Studio Code are two different things and Windows SDK or any of the C++ - tools aren't needed for VSCode.
The module needs it for some reason. I uninstalled it, and now I'm back at square 1.
With Visual Studio whatevers installed I get syntax errors and other stuff, regardless of whether I use pip install RPi.GPIO or whether I download the setup and run it as setup.py install
Collecting RPi.GPIO
  running bdist_wheel
  running build
  running build_py
  creating build
  running build_ext
  py_gpio.c
    running install
    running build
    running build_py
    creating build
    running build_ext
Kits\10\include\10.0.16299.0\winrt" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.16299.0\cppwinrt" /Tcsource/py_gpio    py_gpio.c
I took a look and I see why it wants those: it's trying to compile the GPIO-interfacing stuff from C-code. Alas, it's all Linux-specific.
