Cases that can fit top mounted CORSAIR iCUE H150i
Majorllama
I am looking for cases that can fit the CORSAIR iCUE H150i at the top of the case.
I recently did a build with a 10700k and EVGA 3080 that is getting pretty bad thermals due to the my poor choice of case and the small 240mm rad that cant seem to keep up with the 10700k even at stock clock speeds.
Im looking to stay under $200 for the case and other than that I dont really care about the case as long as it works. Since this does live on top of my minifridge I do need the feet of the case to be 18 1/2 inches apart, but that is the only "rule".
I have been pulling my hair out looking at case reviews for three days and I just cant seem to find one that will for sure fit the 360mm rad at the top without issues.
Quite a few cases can fit a 360mm rad on the top, Fractal makes a few of them.
This may help:
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Meshify C should work, are you using a 240 or 360? you state two different sizes
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
Sorry I should have been more clear. I currently have a 240mm that cannot cool this 10700k properly and I am planning on getting a 360mm rad (CORSAIR iCUE H150i) , but I need a case that for sure can fit it.
Also the Meshify C doesnt support top mounted 360mm. Only front.
Look at the R6, 7, S2, etc.
Or the myriad of other cases that fit a 360mm AIO on top.  You have a lot of choices.
OnePlus:
Other Tech:
im aware, wasn't sure if you were trying to use a 360 or the 240
PC 011 dynamic also fits a 360 on top, not sure if it will fit on your fridge though
AMD blackout rig
The Define r6 and r7 both seem pretty meh in terms of cooling, but they are my favorite to look at. The S2 seems good, but some reviews say it cant fit a 360mm up top. Other options like the 500D keep getting recommended, but the top slot is very restrictive for airflow it seems.
Yeah the PC 011 doesnt work for me at all due to where my tower has to live. Its a looker tho.
Maybe you should look at manufacturer pages instead of reviews?
https://www.fractal-design.com/products/cases/define/define-s2-tempered-glass/blackout/
OnePlus:
Other Tech:
A few options that would be good
P600s
H500m
Panzer max
Meshify 2(maybe) need to double check clearance
